TwinTurbo.NET: Nissan 300ZX forum - TPS is a variable resistor acting as a simple
jzack
on August 01, 2016 at 8:25 PM
Just noticed I'm seeing 5+ volts from TPS
posted by Barry (NJ)
on August 01, 2016 at 06:58 PM
voltage divider. One side of the divider may not be grounded. That would always give the same voltage reading regardless of TPS position. Check your harness connections on both the TPS near and far ends.
O2 sensor issues
Barry (NJ)
22:23:22 07/31/16
Did you reboot ECU after new O2 install? (n/m)
BarryGZX
01:46:45 08/01/16
Reboot the ECU(?)
Barry (NJ)
06:59:42 08/01/16
MAF or vacuum leak. MAF would be the first guess since both
jzack
08:58:09 08/01/16
Boost/Vacuum leak test is clean
Barry (NJ)
12:30:20 08/01/16
2 brand new sensors both being bad...doubtful. I'm
jzack
14:20:19 08/01/16
Low fuel pressure could cause whacky engine conditions
jzack
14:26:07 08/01/16
Checked fuel pressure, 40 psi at idle. (n/m)
Barry (NJ)
22:24:26 08/01/16
Barry (NJ)
18:58:15 08/01/16
TPS is a variable resistor acting as a simple -
jzack
20:25:05 08/01/16
Disconnect your battery...
DVDBURN (MD)
21:16:31 08/01/16
Could the fact that there are only 2
Barry (NJ)
06:19:43 08/02/16
Panel? The ECU bottom cover? (n/m)
DVDBURN (MD)
20:17:53 08/02/16
Actually, I miss read your post...
Barry (NJ)
07:19:22 08/03/16
Ah, you mean the daughter board.
DVDBURN (MD)
15:05:03 08/03/16
What's the reason? Screws provide grounding or is more
jzack
16:09:46 08/03/16
Yes, a ground issue. (n/m)
DVDBURN (MD)
12:23:40 08/06/16
Thought it might have been the SAFC
Barry (NJ)
06:18:15 08/02/16
Barry - did you figure this out? (n/m)
jzack
21:20:25 08/05/16
